Taggy Posted May 6, 2011 Posted May 6, 2011 My car passed the MOT today, but its got a brake bias quite bad of about 24%! also the brakes are pritty shit. They havent felt right since i cooked the brake fluid last year on track.What can cause brake bias and how do i fix it, its got grooved discs and ebc red pads but the peddle feels crap, you have to really push hard on the brakes to get any good braking force.Suggestions? Quote
joel_ep91 Posted May 6, 2011 Posted May 6, 2011 Did you change the fluid and what fluid you use Quote
Amjad Posted May 6, 2011 Posted May 6, 2011 Try Braided lines and some fresh DOT 5.1 Toyota fluid Quote
Taggy Posted May 6, 2011 Author Posted May 6, 2011 its got braided lines already, will have to flush the brake fluid and see how it goes Try Braided lines and some fresh DOT 5.1 Toyota fluid ;) Quote
Keri-WMS Posted May 8, 2011 Posted May 8, 2011 Is that a left > right or a front > rear bias, i'm a bit lost....?By the way once brake fluid has boiled once, from then on it boils at a LOWER temperature! Strange to think that you can "damage" fluid but it's true, so changing it will help. Quote
