StarletMad Posted May 8, 2011 Posted May 8, 2011 Right Ive Decided im not going to pay out YET ANOTHER £600+ for a new manifold an Ext WastegateSo im kinda thinking im going to make my Toyosports Manifold into an externally Gated Mani.Really How Hard Can it be? BanG a hole cutter in the mani and weld a tube into it with a 38mm Flange on the end.Using this you could effectively turn a Normal Mani into Ext. Gated Mani For under £100 Rather Than the £600 for a newen.http://cgi.ebay.co.uk/UNIVERSAL-38MM-EXTER...=item53e75b85fbAnyone done this before?Jono Quote
_shaun_ Posted May 8, 2011 Posted May 8, 2011 its simple if u no what your doing but i belief u can make the mani weaker if u cut wrong place Quote
StarletMad Posted May 8, 2011 Author Posted May 8, 2011 If its braced and you KNOW how to Weld properly ... making it weaker is impossible imo Quote
ollie ryan Posted May 8, 2011 Posted May 8, 2011 wouldnt touch the wastegate in that link matethey are shit! Quote
shorty Posted May 8, 2011 Posted May 8, 2011 Neal gt's motor that the pp boys broke in tgere section had a speedvision mani modded tobexternal gate. Go ceck it out if youbwant some ideas. I nearly did it with my last mani but then decided not to, and shelled out for a whole new mani and decat anyway. Quote
nazzurro19 Posted May 8, 2011 Posted May 8, 2011 i thought i read somewhere that it has to be at a certain angle on the runner to help flow the gases etc , same as ollie that wastegate looks shit and i dont get where the £600 is from i just brought the following..wepr td04 mani and externally gatedecatscreamer pipefmic turbo pipe gaskets and silicone joiners couplers for £455so a mani n decat from him are like £300 deliveredso your toyosports mani kit £190 shitty wastegate £70 thats £260 so extra £40 gives you a decent kit Quote
