thinking of removing the rear wiper as it looks shit, i have removed the rubber gromet from the blade now i thought there was a socket you could fit on there and remove it like that or is that the ep82??
whats the best way to do this, remove the plastic case inside the boot and go from there???
remove the arm. remove the interior trim. un bolt motor, unclip the wiring harness. should drop out or u may have to get a big spanner on it. hope that helps.
remove bolt under grommit and "should" pull off (prob need mole grips and hammer, i did)
then take off plastic inside boot and remove 3 bolts there and the plug!
job done
sorted LMAO i is a dumb ass at times the middle nut was still in i just had to clip the front cover off i was thinking where the hell is it!
Lift the cap of the wiper arm so you get to the bolt, take it off then pull the arm off, then remove interior trim then unbolt = win?
