hi i wana set up my fuel pressure reg but dont no what to set it too
ive got
hdi front mount
relocated air filter
hks actuator
hks fcd
fpr
zisco manifold
hks decat and system
do you recon it will be fine running on 1 bar boost if so what do i set the fpr too??
would take it to a rolling road but not sure where the closest one is.
any help would be good as never set a fpr up befor :)
I would be careful adjusting things like that, should be done properly :)
As above, i'd be carefull. Theres a tutorial on TGTT about this but i think rule of thumb is, 1 bar of boost, 3.1bar of fuel.
As above, needs to be set up properly on a rolling road to make sure your fueling correctly throughout the rev range. If you do it yourself you could end up not fueling correctly and creating BIG problems!
cheers for all the info il set it to 3.1 bar that should be ok to drive it to a rolling road carefully ?
Be aswell leaving it to them to then dude :)
