hello
bought a turbo ct9 of a member with no play
Now the blades have no play in them
But if i push from the exhaust blades to the inlet blade
the whole of it moves from left to right
like below
the ends are straight
is this ok? and normal??
I believe the general rule is that minimal side to side (axial) play is OK up to a point but in out play is a no go.
You get the best sense of movement using both hands on either turbine and move together.
If it's just a small amount (couple of mm's) then it will be fine.
its about
that much?
are all turbos like that or? is it how they sit
im pushing left to right on either turbine(both sides)
and it moves left
then push back
right.
is this shagged and should be recieving a refund? or be fine they all like that?
it doesnt foul anything so to speak. maybe slightly on outside of inlet housing. How much is a rebuild on these? can you do them yourself?
and turns freely.
There is slight play in the inlet blade about 2mm.
The wastegate also has a crack in it?
I rebuilt one using a speedvision rebuild kit. It can be done without balancing but would not be as good. My cousin rebuilds turbo but it would most likely cost more than picking up a descent low mileage one. Think you should try get a refund and find one in better condition.
