tez Posted May 13, 2011 Share Posted May 13, 2011 hellobought a turbo ct9 of a member with no playNow the blades have no play in themBut if i push from the exhaust blades to the inlet bladethe whole of it moves from left to rightlike below /--------//------//-------/the ends are straightis this ok? and normal?? Quote Link to post Share on other sites
wssoR Posted May 13, 2011 Share Posted May 13, 2011 If it's just a small amount (couple of mm's) then it will be fine. Quote Link to post Share on other sites
jezza Posted May 13, 2011 Share Posted May 13, 2011 I believe the general rule is that minimal side to side (axial) play is OK up to a point but in out play is a no go.You get the best sense of movement using both hands on either turbine and move together. Quote Link to post Share on other sites
tez Posted May 13, 2011 Author Share Posted May 13, 2011 If it's just a small amount (couple of mm's) then it will be fine.its about---that much?are all turbos like that or? is it how they sit Quote Link to post Share on other sites
tez Posted May 13, 2011 Author Share Posted May 13, 2011 im pushing left to right on either turbine(both sides)and it moves leftthen push backright.is this shagged and should be recieving a refund? or be fine they all like that? Quote Link to post Share on other sites
jezza Posted May 13, 2011 Share Posted May 13, 2011 If it is moving that much I would expect the blades to be fouling the housings? Do the blades have any damage? Quote Link to post Share on other sites
tez Posted May 13, 2011 Author Share Posted May 13, 2011 it doesnt foul anything so to speak. maybe slightly on outside of inlet housing. How much is a rebuild on these? can you do them yourself?and turns freely.There is slight play in the inlet blade about 2mm.The wastegate also has a crack in it? Quote Link to post Share on other sites
Starbuck Posted May 13, 2011 Share Posted May 13, 2011 They have to be balanced. So unless you have proper equipment, then no you can't rebuild them yourself. Quote Link to post Share on other sites
jezza Posted May 13, 2011 Share Posted May 13, 2011 I rebuilt one using a speedvision rebuild kit. It can be done without balancing but would not be as good. My cousin rebuilds turbo but it would most likely cost more than picking up a descent low mileage one. Think you should try get a refund and find one in better condition. Quote Link to post Share on other sites
