hey guys
can the air filter be relocated with the standard rad in place? is there a kit out there or do i need to source the parts seperate? if i need to sort does anyone have a list of parts?
cheers
leeroy
If you have your air con removed then it's possible.
Monster motor sport sell a kit but it's cheaper to make your own ;)
cheers pal,
yeh i think the first thing im gonna do is remove the air con ;).. then my plan is to get it up to 'stage 1' but i just wanna get bits ready.
As said it is fine with the standard rad providing your air con is removed, not that we need that rubbish anyway ;) ;) lol
if you have your aircon removed then you can just get a 90 degree reducer and use that
if you still have aircon, then you can put it down in the wheel arch, like this:
hope vit, doesnt mind me using his picture.
there are more pics of the pipe routing, although it looks like itd be up to you to measure it and work out what you need in vit's project there, here:
http://www.ukstarletclub.com/forums/index....showtopic=31921
That's a mint place to relocate to, shame you have to remove a fog light for it though.
There is another option to relocate with air con in it's just all very tight.
I'll try find the guide over on TGTT
If you've got standard bumper just drill holes in it track slag style ;) if your putting it in the arch that it is.
cheers all. think i'd prefer just ot run it up in front of the rad without air con as that looks a little messy!!
right just ordered myself a 38-51mm silicone 90 bend, a 51mm 90 degree alloy bend and a universal filter..... i'll let ya know the results ;)
38mm is abitch to get on mate, trust me lol
your better of with a slightly bigger one like 45mm
nothing a little heat wont cure ;)
