relocating air filter with standard rad
hey guys
can the air filter be relocated with the standard rad in place? is there a kit out there or do i need to source the parts seperate? if i need to sort does anyone have a list of parts?
cheers
leeroy
  Electranova said:
If you have your air con removed then it's possible.
Monster motor sport sell a kit but it's cheaper to make your own ;)
cheers pal,
yeh i think the first thing im gonna do is remove the air con ;).. then my plan is to get it up to 'stage 1' but i just wanna get bits ready.
if you have your aircon removed then you can just get a 90 degree reducer and use that
if you still have aircon, then you can put it down in the wheel arch, like this:
hope vit, doesnt mind me using his picture.
there are more pics of the pipe routing, although it looks like itd be up to you to measure it and work out what you need in vit's project there, here:
http://www.ukstarletclub.com/forums/index....showtopic=31921
That's a mint place to relocate to, shame you have to remove a fog light for it though.
There is another option to relocate with air con in it's just all very tight.
I'll try find the guide over on TGTT
