Tyron Devine Posted May 19, 2011 Posted May 19, 2011 Hello people well i have just fired my GT up first time in mounths started first time etc just my idle is abit dogey. Its like its reving its self up it shoots up then down by its self could this be idel control vaulve ? any help would be great. Quote
ollie ryan Posted May 19, 2011 Posted May 19, 2011 give the idle contorl valve a good clean and see what happens Quote
natalie_fuller Posted May 19, 2011 Posted May 19, 2011 could be your tps that has gone/on the way i got the same problem just waiting to pick mine up Quote
rawpower Posted June 1, 2011 Posted June 1, 2011 could be your tps that has gone/on the way i got the same problem just waiting to pick mine upwhats tps got the same problem thanks Quote
LukeH Posted June 1, 2011 Posted June 1, 2011 whats tps got the same problem thanksThrottle possition sensor Quote
whiteglanzav Posted June 1, 2011 Posted June 1, 2011 make sure that you have all the little vac lines on and around the inlet manifold and throttle body connected correctly Quote
nastyrash 2003 Posted June 1, 2011 Posted June 1, 2011 clean out your throttle body. and check battery voltage Quote
bongskag Posted June 1, 2011 Posted June 1, 2011 have you added a dump valve ,? sometimes the vacum line from them can mess with your idle depending if/where its connected..good luck Quote
Tyron Devine Posted June 2, 2011 Author Posted June 2, 2011 have you added a dump valve ,? sometimes the vacum line from them can mess with your idle depending if/where its connected..good luckNo dump vaulve it was my icv in need of a new 1 Quote
