theminiguru Posted May 20, 2011 Posted May 20, 2011 just wondering if anyone has had any issues with creaking or binding noises coming from there meister r coilovers or any other strange things? Quote
ktl Posted May 20, 2011 Posted May 20, 2011 check the adjusters aretight, they loosen themselves sometimes creating a knock/creak. Quote
theminiguru Posted May 20, 2011 Author Posted May 20, 2011 check the adjusters aretight, they loosen themselves sometimes creating a knock/creak.which adjusters buddy? Quote
ktl Posted May 20, 2011 Posted May 20, 2011 the bottom ones, dont touch the 2 that are together in the middle.just make the bottom adjuster is tight. Quote
theminiguru Posted May 20, 2011 Author Posted May 20, 2011 the bottom ones, dont touch the 2 that are together in the middle.just make the bottom adjuster is tight.k ill take a look buddy. thanks Quote
jham Posted May 20, 2011 Posted May 20, 2011 Managed to sort mine in the end... But you know my feelings on these things ha! Seems they work there way loose often gotta check them every so often Quote
theminiguru Posted May 23, 2011 Author Posted May 23, 2011 Managed to sort mine in the end... But you know my feelings on these things ha! Seems they work there way loose often gotta check them every so oftenWhat was the prob with yours in the end bud? Quote
TBDevelopments Posted May 23, 2011 Posted May 23, 2011 i had topnuts coming loose on mine, but quick strip down and thread lock and problem sorted.about 12 months ownership now, very happy with mine not any issues touch woodTimTB Developments Quote
Idrees Posted May 24, 2011 Posted May 24, 2011 I was just going to suggest the same as above. The front coilovers have a big nut at the top, try to tighten that up as mine came loose on my old Glanza and sounded quite horrible! Quote
