tez Posted May 24, 2011 Posted May 24, 2011 Put a new bearing in. All ok. Literally off my drive and dunk. Came back on drive! Jacked up. Play. Up down left and right. So got new hub. No play. Fitted. No play. Drove again off drive. N dunk. Jack up. Same again. What could this be? The noise is then wen pulling off in reverse. Like a dunk. Coming from wheel bearing area?I've checked hub. 23 splinesShaft. 23 splines. What could this be? Any ideas?Play is. Left n right. Up and down. Quote
GT Phayer Posted May 24, 2011 Posted May 24, 2011 is the nut coming loose mate i had that on my sr ? Quote
tez Posted May 24, 2011 Author Posted May 24, 2011 The 30mm on end?How tight is it suppose to be??? Quote
GT Phayer Posted May 24, 2011 Posted May 24, 2011 has a certain torque setting mate its pretty tightbasicly crank it right up to secs il find the torque setting Quote
GT Phayer Posted May 24, 2011 Posted May 24, 2011 216 nm mate http://www.toyotagtturbo.com/forums/showth...TE-Torque-Specs i had to lock tight mine to it kept coming loose Quote
