N80Jamie Posted May 25, 2011 Posted May 25, 2011 Just finished heat wrapping my exhaust so it's ready to fit tommorow. The backbox hangers on my current Fujitsubo exhaust are different to the Japspeed hangers. How do i go about fitting the new back box? Heres pictures to explain what im on about:Fujitsubo HangersJapspeed HangersCheers guys Quote
WallaceGlanza Posted May 25, 2011 Posted May 25, 2011 That'll probably be the hanger for an ep82 on the new exhaust so you'll need to get new hangers welded on the back box to suit the glanza. Quote
Idrees Posted May 25, 2011 Posted May 25, 2011 No, the new exhaust has the correct hangers for the EP91. However it looks like someone has welded something to the original hangers on your car to fit the Fujitsubo exhaust, they have welded 2 exhaust hangers over the original ones! They will need cutting off, and the Fujitsubo exhaust will require the correct hangers to fit another Glanza. I've never seen another EP91 like that. Quote
Lukew360 Posted May 25, 2011 Posted May 25, 2011 Yep x3! As standard on mine I had a long rubber mount that needed trimming to fit into the Japspeed hangar Quote
vit Posted May 25, 2011 Posted May 25, 2011 there is an extension on your original one ,which is bolted to the original one,remove the bolt it will come out which will leave you with the original pin, japspeed will fit with the ep91 rubber square one...easy fix,hope that help.. Quote
N80Jamie Posted May 25, 2011 Author Posted May 25, 2011 Cheers for the replys guys! Does that mean I need to buy a new rectangular rubber thing? Lol Quote
N80Jamie Posted May 25, 2011 Author Posted May 25, 2011 Awsome, I'll get that ordered tommorow then! How long do things tend to take when ordering from Toyota? Quote
WallaceGlanza Posted May 25, 2011 Posted May 25, 2011 oh well i r wrong! Mine never had the original hanger when i got the car either then. Quote
TBDevelopments Posted May 30, 2011 Posted May 30, 2011 correct you need the Toyota exhaust rubber. or you can get it from 99% of parts motor-factors.the original hangers are still in place, shown by the BLUE arrows, the confusing part is it has a conversion part to mount that back box but i believe you can remove the converter bit by undoing the 2 nuts shown in RED, this will bring it back to normal. the standard rubber then slides into the square part of the hanger on the new back box then slide onto the original mounting pins shown in BLUETimTB Developments Quote
