Personally i Pressed mine out mate the hacksaw trick works but I wouldn't do it!
It also takes quite a beat to remove them so u never know what damage to the mounts you are causing
I remove bushes like that all day long, if you cut through enough then fold the bush in on it's self and they can fall out.
But if you have a press then it maybe less work involed.
Jack
