scutch0 Posted May 29, 2011 Posted May 29, 2011 Got a couple of questions about my seo.Firstly, the car was sold to me with the alarm not working, I've tried the holding both buttons on the remote trick but still no luck... I'm assuming someone has disconnected it, so where am I looking for either a fuse or the connections to plug it back in, and what other faults are known with this system?And just a quick one... Im sure I'm right on this one but I just wanted to clarify, does the starlet exhaust system fit the seo? Looking at it, it seems identical to the starlet one apart from the longer tailpipe. Quote
scutch0 Posted May 29, 2011 Author Posted May 29, 2011 Yes mate, factory fitted. It's got the Toyota logo on the fob... Can't see any stickers or anything on the siren though?Also on a separate note, she's overfueling... So gonna try a new lambda sensor... Cheapest I can find is a crimp your own Job on eBay, anyone got a good working order one kicking about? Quote
Galliano Posted May 31, 2011 Posted May 31, 2011 Theres also an alarm sensor under the centerconsole just behind the handbrake. Screws are each side two to the front of the seat, two to the back, lift that up and you may see it. Quote
