Hi guys
I need to know whether a Auto TPS will work on my manual Glanza running on an Emanage Ultimate. I am using a 7AFE TPS which is the same as an Auto Starlet one however I'm having idling issues. My mate thinks the sensor won't work on the manual unless I have a standalone ECU. That sounds right but can someone please confirm this?
Cheers
Idrees
I'll try that too, but for now bump for any info! I need to know whether it will work? I don't have the original TB on and the stock manual TPS doesn't suit my new throttle body.
I was running my stock ecu without the stock tps sensor. The idle bad a bit hight that's it really. You should be able to use any true tps sensor on the ultimate if it has inputs for it. I run a Saab sensor on my standalone.
