dai_starletN/A Posted June 1, 2011 Posted June 1, 2011 hi guys i have a bit of an issue with fitting my fte thottle body to fte manifold on my N/A.the problem is that the throttle sensor connector on the car is different to the one on the TB. as in the keyways that guide the connector on are in a different position to the plug in the fte sensor.the pics to explain the N/Athe connector on the carthe N/A throttle body sensor plugnow for the fte throttle body sensoras you can probably see you can see what i mean.plenty of help to get this sorted pleasecheers Quote
greasemonkeyspb Posted June 1, 2011 Posted June 1, 2011 maybe long shot but would the n/a throttle body?? fit fte manifold??? only other way would be to buy a multiplug and swap the na for fte one on loom???sorry couldnt be much help lol may be able to help if was lookin in person but harder to tell from pics mate reallyste Quote
dai_starletN/A Posted June 1, 2011 Author Posted June 1, 2011 maybe long shot but would the n/a throttle body?? fit fte manifold??? only other way would be to buy a multiplug and swap the na for fte one on loom???sorry couldnt be much help lol may be able to help if was lookin in person but harder to tell from pics mate reallystei did forget to mention im still using my N/A TB with the FTE manifold its ok. but where to get a multiplug? any help is good help cheers Dai ;) Quote
greasemonkeyspb Posted June 1, 2011 Posted June 1, 2011 wont that sensor swap over?? if not mate could try running the 3 wires with little terminal on them so could get car running till can find a multiplug? like spade terminals?? if u know what i mean???may get car running mate ste Quote
dai_starletN/A Posted June 6, 2011 Author Posted June 6, 2011 BUMP.. anyone else have any other suggestions? Quote
ryan lang Posted June 6, 2011 Posted June 6, 2011 could be off a GT dude, maybe the connectors where different to the glanza ??? possits not an auto tb because they have 4 pinsmy FTE sensore on the TB is definitely different to your FTE, TB and mine was off a GT so my above statement has no relevance what so ever lol my bad mate, unless sparky bought an FTE from a glanza for his GT :S confused myself now so god nows where your head is lolbut yeah not sure what you can do about yours dude, apart front solder some wire between the connectors?? if that would work Quote
dai_starletN/A Posted June 6, 2011 Author Posted June 6, 2011 could be off a GT dude, maybe the connectors where different to the glanza ??? possits not an auto tb because they have 4 pinsmy FTE sensore on the TB is definitely different to your FTE, TB and mine was off a GT so my above statement has no relevance what so ever lol my bad mate, unless sparky bought an FTE from a glanza for his GT :S confused myself now so god nows where your head is lolbut yeah not sure what you can do about yours dude, apart front solder some wire between the connectors?? if that would worki thought it was off a GT when i first looked at it lol . plus i dont really want to splice in to the loom incase something does go wrong.cheers anyways dude keep it coming guys the more the merrier Quote
