nazzurro19 Posted June 2, 2011 Posted June 2, 2011 im finally getting ready to pick up the last few bits and get on with my td04 conversion .. then i hit a brick walli understand when running an external wastegate you can control the boost with either a srping combination or a EBCwell ive got an EBC and im slightly confused on how to pick a spring .. have i got this rightif i was to use a 0.7 bar spring then all the way up through the revs there will be no boost as the pressure builds then when i hit 0.7 the boost will all come in at once ? or is it i will build boost up but at 0.7 the spring will be fully open so then ill hit more boost ? so surley is it not best to get a 0.3 bar spring etc?any explanations would be muchly appreciato Quote
rorenapier Posted June 2, 2011 Posted June 2, 2011 Your thinking is all wrong.Think of the External wastegate like an actuator, set your base pressure and go from there. Simples. Quote
Ryan-11 Posted June 2, 2011 Posted June 2, 2011 if u have a 0.7 bar spring u wont be able to set the boost lower than 0.7 (so low boost will always be 0.7) but u can turn the boost up with a boost controller, if you aint using a boost controller then u will only boost to 0.7so what ever boost u want to run for low boost use that spring. Quote
nazzurro19 Posted June 2, 2011 Author Posted June 2, 2011 ahh so if i got a 0.7 bar spring i could still boost to like 0.3 on the gauge and get a lil power same as now then ? Quote
N80Jamie Posted June 2, 2011 Posted June 2, 2011 If you got a 0.7bar spring you could never boost lower than that unless you get a new spring Quote
Ryan-11 Posted June 2, 2011 Posted June 2, 2011 ahh so if i got a 0.7 bar spring i could still boost to like 0.3 on the gauge and get a lil power same as now then ?Yeah thats right, as Rory said its really just the same as setting an actuator to 0.7 Quote
nazzurro19 Posted June 2, 2011 Author Posted June 2, 2011 yeah this is whats confusing me ... you say i wouldnt be able to boost lower then .7 ?but surly when i put my foot down its guna build up .1 .2 .3 .4 .5 .6 etc ? or will i just put my foot down nothing happen then all of a sudden BOOOOOOOOOOOOOOST Quote
N80Jamie Posted June 2, 2011 Posted June 2, 2011 Your still going to get lag so yes in effect you will be going 0.1, 0.2 etc. Your full boost is going to be 0.7 though and nothing lower. Quote
Ryan-11 Posted June 2, 2011 Posted June 2, 2011 yeah this is whats confusing me ... you say i wouldnt be able to boost lower then .7 ?but surly when i put my foot down its guna build up .1 .2 .3 .4 .5 .6 etc ? or will i just put my foot down nothing happen then all of a sudden BOOOOOOOOOOOOOOSTIf u have a .7 spring and have a boost controller fitted and set it to boost at .4 it wont boost at that because u have a .7 spring in the wastegate. thats what he means by not being able to boost lower than that, It still builds up boost the same Quote
nazzurro19 Posted June 2, 2011 Author Posted June 2, 2011 well atm i have a 1 bar spring in there and the most i want to map/run is 1.2/3 so if i keep this spring i will just never hit full boost unless im ragging it or down the strip etc so really getting a lower spring is pointless ? cause i aint fussed at hitting full boost at any lower Quote
string Posted June 9, 2011 Posted June 9, 2011 I've got a .45 spring of you want it. Tenner plus postage. Then ya can run low boost for chillin as a td at a bar is quite a kick. Up boost to whatever with a controller. Plus it'd be safe at .45 till ya have injectors mapped etcTo answer ya question u can boost lower than spring pressure but full boost will be set at 45 till ya turn it up on controller. it comes on gradual like the ct9 but after .4 mine rises fast to 1,1 Quote
nazzurro19 Posted June 13, 2011 Author Posted June 13, 2011 does anybody know if a tial spring will fit in a turbosmart wastegate? like are they all universal etc or do i hve to buy a turbosmart one? Quote
