stevogt Posted June 3, 2011 Posted June 3, 2011 hey all i have searched for the problem but found nothing helpful,Im loosing pressure on my clutch pedal if i depress the clutch it re engages slowly theres no leaks anywhere i have topped up the fluid and bled the slave but was wondering if anyone has had the same problem and where to start the fluid pot or the cylinder on the box thanks in advance.Ste Quote
Socks Posted June 3, 2011 Posted June 3, 2011 slave cyl seal might be knakered...try re-bleeding Quote
stevogt Posted June 3, 2011 Author Posted June 3, 2011 im guessing there would be fluid passing through the rubber bung i had the same problem on an mr2 i had years ago il give it another blast at bleeding and see how i go thanks. Quote
Socks Posted June 3, 2011 Posted June 3, 2011 lift the rubber boot see if the internal seal is fucked dude there only cheap things to replace so no biggy Quote
stevogt Posted June 3, 2011 Author Posted June 3, 2011 right i checked behind the rubber and its busted put a new one on still f***ed think its took the master cylinder with it im hoping its just popped the seal off when i strip it tomorrow are there any other toyotas with the same cylinder in case its a scrapyard jobbie as im low on funds this week there only £57 new but bills come first loll thanks for your help.Ste Quote
aidanep71 Posted June 3, 2011 Posted June 3, 2011 right i checked behind the rubber and its busted put a new one on still f***ed think its took the master cylinder with it im hoping its just popped the seal off when i strip it tomorrow are there any other toyotas with the same cylinder in case its a scrapyard jobbie as im low on funds this week there only £57 new but bills come first loll thanks for your help.Steu best of waiting til ya have the money for a new one as its a common problem with toyotas so a s/h one might not last either Quote
stevogt Posted June 4, 2011 Author Posted June 4, 2011 yea think i will wait no point doin the job twice and it will be all fresh thank you for your replies.Ste Quote
