anyone got any tips of how to remove wind deflectors without snapping them. i want them off my white gt to put on my green one but heared there a complete and utter bitch to remove
anyone done this before successfully?
just take the clips out and run a sharp stanley blade through the sticky foam between the wind deflector and door as you prise them off gently and they will come off no bother
no mate just pry them off gentley while running the blade thought the foam and they will come off easy. move along with the blade as you pry it apart, dont just pull it off from one end or it will snap.
THis^^
I whiped a pair off in 5 mins, window down, clips off, stanley blade through the foam, and boabs your fathers brother.
As above, it's really easy. Pull the window down and pull off the rubber seal around the top to make it easier to remove the clips too. B)
