Blitz Posted June 7, 2011 Posted June 7, 2011 as above my loversoff and 82i have a 91 this wont be a problem will it? double checking like Quote
5T4R7ET N/A Posted June 7, 2011 Posted June 7, 2011 yeah it will be a straight swap if already have a LSD box. Quote
Jamie1st Posted June 7, 2011 Posted June 7, 2011 Might be wrong, but are the gear ratios different on the ep82 box?Jamie Quote
Blitz Posted June 7, 2011 Author Posted June 7, 2011 i dont already have an lsd box "/ and im not sure jamie mate "/ Quote
nazzurro19 Posted June 7, 2011 Posted June 7, 2011 it will be a straight swap if its a box with an aftermarket lsd and yeah the ratios are differnt the glanza has shorter ratios so ya get faster acceleration if this gearbox is a factory lsd optional extra then ull need the shorter driveahaft and gearbox mount Quote
Idrees Posted June 7, 2011 Posted June 7, 2011 If it has a Kaaz LSD then it will not have a factory LSD.In answer to your questions; yes you should take it at £400 if it's in good working order, and yes it will fit your Glanza. 3rd and 4th gears will be a bit longer, I personally prefer this gearbox especially with a bigger turbo. Quote
