Toyota Paseo - Second Generation - 1996-1999
Welcome to the Second Generation of the Toyota Paseo. Here is where you will find a whole bunching of information to do with the Paseo and where it all started from.
Here is a run down of what you will see in this topic:
  • Explanation of Chassis Codes
  • Model Guide (Explaining Base, Higher and Limited Models by country)
  • Engine Code Explanations
  • General Information (Weights, Dimensions etc)
Chassis Codes - Explained
The Gen2 Paseo/Cynos is commonly known to petrol heads as the EL54 (or L5 shortened commonly used in some European countries). But it is a little more complex.
The EL platform is close to that of the Starlet, Sera and Corolla - Sharing much with each, hensefourth often nicknamed Corolla (or Starlet) Coupe.
Codes and Referances:
EL52 - Commonly on JDM Cynos Juno models. This means it has the 1.3 4efe engine with an automatic gearbox.
EL52c - Commonly on JDM Cynos Juno Convertible models. This means it has the 1.3 4efe engine, automatic gearbox and is in Convertible form.
EL54 - Common accross most countries Paseo and Cynos. This means it has the 1.5 5efe or 5efhe coupled with a manual gearbox.
EL54c - Commonly known in the US and Japanese markets. This is the 1.5 5efe/5efhe models with manual gearbox, but in Convertible form.
Photographic referance to such models will be found in links in the below section.
Model Guide By Country
Here is an explination of what base or higher models were available to which country. This is simple name and engine variants listing. To determine what the models have, click the green writing to link to a factfile on that particular model, showing all of its advantages.
United Kingdom:
ST - Base model with 1.5 5efe engine and 5 speed manual gearbox
Si - Higher model with 1.5 5efe engine and 5 speed manual gearbox
Galliano - Limited Edition with 1.5 5efe engine and 5 speed manual gearbox
Japan:
Juno - Base model 1.3 4efe with 4speed automatic gearbox
Alpha - Mid range model with 1.5 5efe engine with 5 speed manual gearbox
Beta - Higher model with 5efhe engine and 5 speed manual gearbox
Juno Convertible - Base model Convertible with 1.3 4efe engine with 4speed automatic gearbox
Alpha Convertible - Mid range Convertible model with 1.5 5efe engine and 5 speed gearbox
Beta Convertible - Higher Convertible model with 1.5 5efhe engine and 5 speed gearbox
Holland:
'Paseo' - No model name for this one, just Entry Level with 1.5 5efe engine and 5speed manual gearbox
GT - Higher model with 1.5 5efe engine and 5 speed manual gearbox
Germany:
S - Limited Edition with 1.5 5efe engine and 5 speed manual gearbox
'Convertible' - No model name for the Convertible, with 1.5 5efe engine and 5 speed manual gearbox
Facelift - No amazing changes with 1.5 5efe engine and 5 speed gearbox
4E-FE - 1331cc engine producing 88HP 87ft-lbf (118 N-m) Torque. Available in Japan and Australia (and possibly other countries). This is a rare engine for the Paseo/Cynos.
Also found in:
Toyota Starlet EP80, EP82, EP85, EP91 and EP95.
Toyota Tercel
Toyota Corolla
5E-FE - 1497cc DOHC engine producing 93HP 100ft-lbf (136 N-m) Torque. Available across the world. Most Paseo/Cynos models have this engine. See above for exact models and engines.
Also found in:
Toyota Corolla
Toyota Corolla II
Toyota Tercel
5E-FHE - 1497cc engine producing nie on 100hp, Torque figures to be clarified.
Also found in:
Toyota Sera
General Information
Width:
1,661mm
Height:
1,295.4mm
Length:
4,155mm
Curb Weight:
To be completed later this evening... all being well.
