rob_bower Posted June 11, 2011 Posted June 11, 2011 Horn keeps stopping working! But then if you hold it down you get a short burst then it stoops again I was thinking loose conection any other ideas? Quote
Amjad Posted June 11, 2011 Posted June 11, 2011 Mine puts out a warbling beep like it's dying I know it's defo a loose connection on mine.. Quote
rob_bower Posted June 11, 2011 Author Posted June 11, 2011 I went to use mine in the way to work and nothing! So I kept repeatedly pushing it still nothing! So I held it down for a bit then I got a short beep the I'd died again! Will have to take it apart at some point and find out what it is! Quote
Dean @RW-Developments Posted June 11, 2011 Posted June 11, 2011 it will most probably be a bad earth! unbolt the horn and sand the metal down behind. Quote
slatertwin Posted June 11, 2011 Posted June 11, 2011 it will be a bad earth mate, mine has done the same a couple of times. Quote
rob_bower Posted June 11, 2011 Author Posted June 11, 2011 Cheers guys will try and strip it down at some point! Quote
rob_bower Posted June 14, 2011 Author Posted June 14, 2011 sorted!!looks like it was a bit of eveything earth was rusty as (the earth is seperate on the alpha horns) and a loose connection on the spade conector!!cheers guys Quote
