hill_bill10 Posted June 14, 2011 Posted June 14, 2011 can anybody point me in the right direction to adjusting my handbrake from the drums?cheers Quote
LukeH Posted June 14, 2011 Posted June 14, 2011 can anybody point me in the right direction to adjusting my handbrake from the drums?cheers can you just adjust the cable next to the handbrake lever ?take of the plastic cover and then tighten the 10mm nut.im thinking of a gt handbrake but cable should be same surely. Quote
hill_bill10 Posted June 14, 2011 Author Posted June 14, 2011 yeh u can but they need adjusting at the drum because its only not working on one side Quote
james@cjperformance Posted June 14, 2011 Posted June 14, 2011 Yes you can adjust at the drum.30mm nut undo it and remove the drum.Inspect the brake shoes and cylyners for uneven wear and fluid leaksYou will see at the top there is a spring mechanism with a sort of cog attached you need to tun it to adjust the brake shoes.Clean up the drums and refit Repeat on both sides until both brakes seem to be the same.Note:you will have to do this with the handbrake off:) Quote
Raz Posted June 14, 2011 Posted June 14, 2011 FUCKING HELL, thats allot of hassle. I was hoping it was something simple. Quote
james@cjperformance Posted June 14, 2011 Posted June 14, 2011 Its worth doing mate if you adjust it on the handbrake you will just end up stretching the cables:) Quote
Johnboy GT Posted June 14, 2011 Posted June 14, 2011 Thats an easy job! Well worth doing though! Exactly how James said aaswell.John Quote
james@cjperformance Posted June 14, 2011 Posted June 14, 2011 I find it easier than changing hanbrake cables on the deck lol get it done Quote
hill_bill10 Posted June 14, 2011 Author Posted June 14, 2011 yeh, got it done, its not as hard as it sounds, hardest bit is gettin the drum off because its so old and rusty lol Quote
james@cjperformance Posted June 14, 2011 Posted June 14, 2011 Hit shit out of it with a lump hammer next time. Come off a lot easier then:) Quote
siren676 Posted June 15, 2011 Posted June 15, 2011 There is an easier way than removing the drums. There is a small hole on the back of the drum that you can fit a flat blade screw driver into. If you have an inspection mirror you should be able to see the adjustment cog inside.Use the screw driver to spin the cog until you get the brakes where you want them. Quote
james@cjperformance Posted June 15, 2011 Posted June 15, 2011 Imo you should remove the drums every time to inspect the brake cylinders and brake shoes for wear.Far better then using the inspection hole. Quote
hill_bill10 Posted June 15, 2011 Author Posted June 15, 2011 yeh its better to remove them and give them a clean up too really, they were rather dusty lol Quote
