quick disc question
discs are NOT the same, early mk1 gt has a 54mm centre bore on the disc and the later gt and glanza model has a 55mm center bore! just make sure they are not mk1 gt discs, having a larger centre bore than you need isnt an issue but aving one thats too small is as it wont go over the hub so the alloy wont sit right :lol:
