Goober Posted June 15, 2011 Posted June 15, 2011 As the title says really.I have a 96 Glanza with a custom stainless steel exhaust, its been on the car since i bought it around a year ago however for the last 3 weeks it seems to be knocking on somthing when ever i drive. I have checked that it is mounted properly and have had all mounts checked over by my local garage, all seems to be ok however it still keeps knocking.After failing on its recent MOT one thing that i thought may have an effect is the near side rear shock which needs to be replaced (been fitted next weekend). Could this be the route cause?Any advise welcome. Quote
ForgedV Posted June 15, 2011 Posted June 15, 2011 Have you got a panard rod mine used to rub on there Quote
Goober Posted June 15, 2011 Author Posted June 15, 2011 Have you got a panard rod mine used to rub on thereWithout sounding too stupid whats one of them mate? Quote
ForgedV Posted June 15, 2011 Posted June 15, 2011 They re alighn rear axle when lowered on coilovers it's basically like adjustable bar that prevents the crabing effect that lowering can cause, mine used to rub on it where the exhaust rubbers had stretched and slackened off a bit making it knock over bumps or make a squeaking noise. Quote
bucketep91 Posted June 15, 2011 Posted June 15, 2011 Find out where it's knocking from first. Mines used to hit the gearbox, I had the downpipe extended a little bit and it solved it, my mates used to knock off the rear bumper bar and it just needed a small adjustment and a new mount Quote
