hello
i know what they both do.
But which is better?
Im looking for EBC for my 1 bar setup
Im running all supporting mods
with a JAM ecu
Few questions
Which one would you recommend?
Easy to wire? easy to use?
Im wanting to run 1 bar of boost max! happy to at 1 bar.
So do i set my actuator lower (0.9 bar) and then raise my boost controller up to 1 bar?
or put the actuator lower and raise the boost with the EBC?
or vice versa? if so what boost should i set my actuator at?
Comments welcomed
cheers
personally i've always turned actuator down and let controller do the rest. plus low boost would be lower. i've always thought a actuator would last longer at a lower boost rather tha pushin a bar everyday.
If your running a HKS actuator, just run a bar from that. IF you dont want to or if you dont have one, AVCR wins hands down.
Once you get your head round it its fairly simple to use.
i have a HKS actuator set at 0.9 bar now
but someone said get a boost controller as it would be better also.
If i was to get a boost controller
should i lower the actuator
and just adjust from boost controller
cheers
