hi need abit of info on my brakes my handbrake light comes on when i give the brakes a firm press I've checked the level and seems fine the abs is working. I've looked at the handbrake swith and this is working im puzzeld any one can shed abit of light on this one cheers
ya it tells ya either your nearly out of brake fluid or your handbrake is pulled..try put a bit of fluid in it may not seem low but when ya press the brakes the level will drop slightly
the fluid level is ok think im going to take a look at the pads its still flikering could it be a faulty wire mite sound daft ?
