Ricky@Race-Tech Posted July 7, 2011 Share Posted July 7, 2011 rorenapier said: Remove the blanking plugs from the 2 top ports, and plug the other 2 bottom ports, and try that.As above. This is your problem. What you've done is effectively fitted a HUGE bleed valve, you'd just make infinite boost. Quote Link to post Share on other sites
Idrees Posted July 7, 2011 Author Share Posted July 7, 2011 That's what I did last night Rory and is sorted, I knew those bottom 2 shouldn't have been open lesson learnt! Cheers guys! Quote Link to post Share on other sites
