So the previous owner had a aftermarket ECU in the car (Blitz I think?) and took that out when selling the car. Replaced it with the standard ECU. Turbo seems a little laggy.
Is there a way of like re-setting the standard ECU again or what can i do to solve the issue?
Its still boosting fine at .6 it just seems to be a little laggy.
I would just keep driving it, it may take a little while for it to settle in depending on how long you have had the car? Disconnecting it again won't make a difference just keep the boost down without having a fcd or ebc.
the difference between the map on a standard ECU compared to a plug and play is big, when i removed my JAM ECU and went back to standard the car was noticebly slower and didnt come on boost as soon
