gt-nick Posted July 18, 2011 Share Posted July 18, 2011 hey people ive had to strip down my engine as a stone went through rad and made a big mess so me being in a rush to get it off i never timed it up and relised once i took the cams out its not like a normal 16v so now im wondering how i get the inlet cam timing right ? Quote Link to post Share on other sites
Whitegv Posted July 18, 2011 Share Posted July 18, 2011 There are 2 dots on the inlet cam gear and one.big.one on the exhaust gear. line those up and your away mate Quote Link to post Share on other sites
gt-nick Posted July 18, 2011 Author Share Posted July 18, 2011 There are 2 dots on the inlet cam gear and one.big.one on the exhaust gear. line those up and your away mateok cheers mate Quote Link to post Share on other sites
Russleh Posted July 19, 2011 Share Posted July 19, 2011 you will also notice that the inlet cam gear is split. you should have placed a bolt through the service hole to keep it under tention so that when its put back together it helps mesh the 2 gears better russell Quote Link to post Share on other sites
rorenapier Posted July 19, 2011 Share Posted July 19, 2011 Doesnt help mesh anything, it stops the inlet cam rattling. Quote Link to post Share on other sites
Russleh Posted July 19, 2011 Share Posted July 19, 2011 Thats what i ment. Somethin that doesnt rattle is working better than something that does , no ?Russell Quote Link to post Share on other sites
rorenapier Posted July 20, 2011 Share Posted July 20, 2011 You never mentioned rattling, you stated "it helps mesh the 2 gears better "They mesh together fine even when you dont tension the cam gear, hence i posted what i did. Quote Link to post Share on other sites
Russleh Posted July 20, 2011 Share Posted July 20, 2011 Meh. Not gonna argue over something so pointless. Knew what i ment by it Quote Link to post Share on other sites
