TrisK Posted July 20, 2011 Posted July 20, 2011 when car is off, should the dial be at 0?as mine is at 1?so this might mean im running a bar less fuel pressure than i think i am? maybe thats causing my stuttering issueif im right and the dial is wrongis the dial a) showing 1 above what it shoud be, meaning im running a bar lower than i think dial is getting stuck and cant go below 1, but not affecting readings above oneany ideas? Quote
Fro Posted July 21, 2011 Posted July 21, 2011 I think its ok, but i wouldnt take my word as gospel cause im not 100% either! But when I switch my car off my gauge takes a good while to drop which i was told is normal, cant remember if mine goes to 0 or not!? Quote
TrisK Posted July 21, 2011 Author Posted July 21, 2011 I think its ok, but i wouldnt take my word as gospel cause im not 100% either! But when I switch my car off my gauge takes a good while to drop which i was told is normal, cant remember if mine goes to 0 or not!?i thoght it might of been residual pressure?the car will be sitting all day today, so if i remember when i get home ill have a look at the dial Quote
