when car is off, should the dial be at 0?
as mine is at 1?
so this might mean im running a bar less fuel pressure than i think i am? maybe thats causing my stuttering issue
if im right and the dial is wrong
is the dial
a) showing 1 above what it shoud be, meaning im running a bar lower than i think
:) dial is getting stuck and cant go below 1, but not affecting readings above one
any ideas?
I think its ok, but i wouldnt take my word as gospel cause im not 100% either! But when I switch my car off my gauge takes a good while to drop which i was told is normal, cant remember if mine goes to 0 or not!?
i thoght it might of been residual pressure?
the car will be sitting all day today, so if i remember when i get home ill have a look at the dial
