Just going to be blunt, had an immensely crap year so far...
Parents split up, finished my 3 years at college (nothing to do) cant find a job what so ever and now my car finally has had it with me :o
I had my MOT roughly 2 weeks ago and it passed fine with no advisories, but it only just about squeezed through on emmisions, The place i took it to specialise in rebuilding engines etc.
To cut to the chase, my cars burning oil at high revs (blue smoke from exhaust) only at high revs though, the chap claimed due to this sign he thinks somethings up with the bottom end :( and he mentioned pistons :/ to add on top a few weeks before that ive noticed my turbo gauge is not reading anymore either :(
Whats the best way to find out everything thats up with my glanza?
Has anyone had this problem?
Ill upload a spec list to see if it helps...
Thanks Guys :D
TOYOTA STARLET GLANZA V: SNOW EDITION SPEC LIST
Spec: 170bhp 163lbf.ft at 0.7bar
ENGINE:
Tong turbo GT spec Hybrid
SPS mild steal manifold
SPS stainless steal decat
Blitz NurSpecR back box with custom 2" stainless steal straight through mid section
HDI front mount intercooler
Aircon removed
HKS actuator
SARD rrfpr
Uprated MR2 fuel pump
HKS ssqs blow of valve
Toy Tuning filter relocation to front bumper
NGK blue ignition leads
NGK irridiam heat range 7 spark plugs
Tuning Developments oil catch can
Greddy oil sandwich plate
Idrees painted blue rocker cover
Steel headgasket
ARB Engine bolts
Electronics:
HKS EVC6 Boost controler
HKS oil temp gauge
Apexi Boost gauge (2bar)
Chassis/Suspension:
15" white Rota Grid's with 4 very good Toyo T1R's
Apex Gen2 Coilovers with 32way damp adjustment
front strutbrace
Whiteline Rear fixed RARB
10mm spacers allround
Exterior:
ZEP Racing CARBON FIBER reverse scoop
white colour coded Glanza decals
OEM optional DUCK SPOILER
Laguna vented front splitter
re located number plate
Refect rear lenses
clear front indicator lenses
Interior:
standard interior
Sony explode CD,ipod headunit with remote
Razo straight shift gear knob
TM Development double gauge pilla pod
OEM Optional armrest
HKS EVC6
Could be burning oil because the turbos fooked? it wouldnt burn oil if the bottom end is on its way out it would just knock like a cunt.. if the piston rings are on the way out then yeah it will burn oil!! if thats the case then get here compression tested to be sure....Also this used to be glanza_cl's car and he had the head rebuilt because the valve seams where fooked so cant see it been them
ok thanks for the advise pal, ill get a compression test sorted out asap, just hoping its nothing major expensive, how much roughly can you get new pistons done if thats the case?
ive managed to find a set of new replacement pistons for £100, how much labour roughly does everyone think it'll cost? :/ sorry about the silly questions
Don't jump the gun mate, let monster take a look if their close by and see what they say first. :)
Yeah sorry im just stressing slightly over how much ill have to spend :) lol but yeah ill make sure i get it checked out properly before i start getting parts for it, i'll keep you all updated
