Hii, Ive got an GReddy Ultimate ready for my setup, but before I go about wiring it all in, is there any way I can test it to make sure it works?
Like send it in to someone that deals with them etc?
Cheers, Jamie
Software, info and other downloads can be found on our emanage forum.
You will need a usb printer cable to link up the unit and your pc/laptop like this one.
If the unit when started lights up amber then it is a very good sign it is still active. A green light means 'plug cleaning mode' which happens when you turn on the ignition on wide open throttle (shuts of injectors when engine is cranked - useful for cleaning wet or fouled plugs and achieving oil pressure without starting the engine after an oil change.
Joz
