you can get a non pas rack from a starlet without the powersteering but im not sure which model that would be. or you could just take everything off and block off the holes in the other rack i think. i havent done it but i have read a thread before on here somewhere. ill be taking mine off my next car aswell so ill need to know for sure :)
Russell
Remove the pump and the pipes, fit a non power steering rack. If you're not going to change to a non P/S rack then don't bother, I tried that on my car and it drove absolutely awful.
thank you both very much look like im off to get a non ps rack yay do i also need any new wheels for the aux belt or jus the non ps belt? and dont spose you know how much the unit actually weighs?
you cant just change the rack as the steering column will be too short,
you will have to find a starlet with non pas, and take the steering column out change the center of the columns over ( held in by a c clip at the top) as the non pas column is longer,
