Ok guys tryed fitting my sard today and it's leaking on the fittings what you use to seal it up had to put it back to standard till I can stop it leaking thanks in advance nick
i had the same problem if u gets some ptfe tape or plumbers sealing tape and wrap it around the threads then do the unions up tight it will seal.
  • 2 weeks later...
