Raz Posted August 3, 2011 Posted August 3, 2011 My cars coming up 200k and the gears are abit of a fiddle to select. I've been reading on the other forum on how to change the sugar cube, but in the tutorial on there the gearbox is off the car. How do i do it while its on the car, How does the sugar cube come out? And who else has done it? Quote
WallaceGlanza Posted August 3, 2011 Posted August 3, 2011 Take the cable off by removing the R clip, then unbolt the linkage with the cube and simply pull the cube off and turn it. Quote
TBDevelopments Posted August 3, 2011 Posted August 3, 2011 this is a common wear item on the 3sgte gearbox as well that i deal alot with. i'm just about to release a product that actually replaces that solid block with a nice little roller bearing washer that stops it from wearingi'll post it up once i get some in againTimTB Developments Quote
Raz Posted August 3, 2011 Author Posted August 3, 2011 Am i correct in thinking that this is where the Sugar Cube is located on the car?I just removed it from the car and it just seems to be a plastic rectangle thing Unfortunatly i didn't get pics of that as i was shocked and thinking WTF. So i put it back then i though hold on, is this even the correct place?It may have been replaced by previous owner as he done a fair bit of work to it. Quote
turbo Grant Posted August 5, 2011 Posted August 5, 2011 That's the one dude. Should be a soils square pice of metal with whole in. You can turn it round or get a new one from toyota for £12. Check the cable bushes that go on the gear box. The go overal after a while. Quote
Raz Posted August 5, 2011 Author Posted August 5, 2011 yh i removed that cube, but it wasn't a metal cube, it was plastic and it was a rectangle :S Quote
Asad Posted August 5, 2011 Posted August 5, 2011 i spotted this also, what year car do you have? my 96 N/A only had the mentioned plastic item and not the metal "sugar cube" seems as if toyota saw the problem and rectified it....in this case there is nothing you can do put some grease on it and rule it out fix/replace something else Quote
turbo Grant Posted August 5, 2011 Posted August 5, 2011 Check the End of the cables that slot onto the selector. The might have warn and need replacing. Quote
Raz Posted August 5, 2011 Author Posted August 5, 2011 i think i'll grease up the rods and links, Any recommended grease? Quote
