I've got a full tank of petrol, but last night after starting up the car the fuel light decided to stay constantly on which was annoying, is it just a sensor that's stuck? Anyone had this problem before?
  • 5 months later...
  • 4 months later...
My light has never come on either when its dangerously near empty.
Joz
I never run mine any lower then 1/4 as thats when you start to suck up the shit from the bottom of the tank. Not good
  • 2 weeks later...
The sender is under the back seat. Your better removing it with a near empty tank of fuel. You will need a 8mm socket and ratchet to remove it. And the whole picking up crap from the bottom of the tank........ The fuel pump is at the bottom of the tank. It has a gauze on it to prevent any debris being picked up by the pump.
