put my glanza back to nearly enough standard engine.
cat
front mount intercooler
air filter normal position.
standard ecu
ported manifold
no boost restriction(completely removed, no solenoids.
In second gear I carnt get the 3 boost lights to come on.
i can get two.
My actuator has the vac hose from top to turbo
and the spare line from actuator that is supposed to go to the boost solenoid. is left open.
(nothing blocking it off.
the standard dump valve(recirc thingy)
i have no lines attached to this. as i have a DV and a breather filter on rocker.
any ideas??
cheers
im getting around 0.5 bar on my boost gauge/maybe 0.6
baileys dump valves are bad for boost leak. try blocking it off then take it for drive to rule it out.
I had the same problem and i had a baileys at the time so it got flung and bought a hks bov, I agree with lee try that just to rule it out.
Bryan
  • 6 months later...
Hey guys i have a question,
i have an oem turbo CT9 with a HKS actuator on it but i have noticed that my car really begins to boost @ 4000rpm it did do that before can you guys know why it's doing that and if there is a way to fix it?
Best regards
