needing some advice
Hey Guys,
I bought a ball bearing turbo of ebay, it was ment to have covered under 500km and in perfect working order, i received it yesterday and has mega shaft play, the blades on the inlet side hit the housing and theres a crack in the wastegate. The seller says the shaft must off got damaged while getting delivered (whitch i highly dout as it was very well packed) and that its commen for a wastegate to crack when on the dyno?
also is it possible for the blades to wear down against the housing?
cheers
Ryan
youve been had dude, did you pay via pay pal? if you did get onto them and keep any e-mails or contact youve had with the seller. abd get your money back.
Yeah i payed through paypal, just away to start up a dispute, ive got all the emails he sent.
