LeeroyV Posted August 19, 2011 Posted August 19, 2011 had my tracking sorted on the glanza yesterday and geez it was out but whilst up in the air i had a quick peek underneath and saw my nearside CV boot in a sorry state. im gonna look to replace it it but camskill list a 23/23 or a 23/30 spline kit.. which one do i need???? Quote
Matt1878 Posted August 19, 2011 Posted August 19, 2011 I changed the 2 on mine when i first got it.. I needed a 23/30 .. I got a 97 Glanza.Also if you got ABS i had to choose from an 8mm ring or 11mm and it was the 8mm i needed.Hope this helps Quote
micky boy Posted August 19, 2011 Posted August 19, 2011 Dose your car have oem LSD? if so then i think it will be the 23/30spline If you have a non LSD box it will be the 23/23spline Quote
LeeroyV Posted August 19, 2011 Author Posted August 19, 2011 right that helps thanks guys... yeh got abs although it aint working atm. how do i check if box has LSD or not??? Quote
t-j-wilson Glanza V Posted August 19, 2011 Posted August 19, 2011 Jack one wheel up with it in neutral, if the wheel spins you haven't, if it doesn't spin you doo CHeers for this topic as i also needed to know this haha Quote
