ep91_glanza Posted August 20, 2011 Posted August 20, 2011 I looked at the torque specs on tgtt and it said1st 22nm2nd 44nmthe 3rd had 90o is that degree turn or 90 nm thanks for help in advance Quote
ToyotaTech15 Posted August 20, 2011 Posted August 20, 2011 The last sequence is a 90 degree turn,Mark the head of each bolt so you know when your at the 90 degrees as you don't want to overtighten Gary Quote
