ep91_glanza Posted August 22, 2011 Posted August 22, 2011 Ive just fitted my engine andBefore it was set at 1.0 bar but now it wont go past .5 bar ive tried turning boost up but dosnt make any difference.can any of yous help??? Cheers karl Quote
RobSR Posted August 22, 2011 Posted August 22, 2011 check for boost leaks, leaving vac pipes off etc.. Quote
ep91_glanza Posted August 22, 2011 Author Posted August 22, 2011 check for boost leaks, leaving vac pipes off etc..i think the hotpipe that goes on the turbo is leaking but i didnt think that would lose so much boost would it?? Quote
RobSR Posted August 22, 2011 Posted August 22, 2011 if you have a big enough it will easily mate.. go back and make sure all your ic pipes are together and jubilee clips are tight etc... Quote
ep91_glanza Posted August 22, 2011 Author Posted August 22, 2011 if you have a big enough it will easily mate.. go back and make sure all your ic pipes are together and jubilee clips are tight etc...ive checked everything nd thats the only thing that it might be,but even if i alter the boost would i not see a change ? Cheers Quote
ep91_glanza Posted August 28, 2011 Author Posted August 28, 2011 ive checked everything nd thats the only thing that it might be,but even if i alter the boost would i not see a change ? Cheersi took the vaccum pipe off the actuator and it is now wanting to boost loads so could it be a dodgy actuator or?????cheers Quote
ep91_glanza Posted August 28, 2011 Author Posted August 28, 2011 i took the vaccum pipe off the actuator and it is now wanting to boost loads so could it be a dodgy actuator or?????cheerscan someone help??? Quote
