epyank Posted August 23, 2011 Posted August 23, 2011 the throttle body plug from the engine loom is has 4 connectors but the actually plug on the inlet manifold is a 3 plug and thats where the wire goes...what do i do?? Quote
ryan lang Posted August 23, 2011 Posted August 23, 2011 i think the 4 pin is for the auto, so is it an auto loom? Quote
epyank Posted August 23, 2011 Author Posted August 23, 2011 i have no idea mate but if your right then fuckd Quote
ryan lang Posted August 23, 2011 Posted August 23, 2011 yeah im pretty sure the auto came with 4 pins you can probably use an auto tps though i would have thought because a few people have done auto to manual conversion and i dont think any of them have changed the tpssome one else will have to confirm this though Quote
micky boy Posted August 23, 2011 Posted August 23, 2011 Are you puttting a glanza throttle body on orr something? Quote
epyank Posted August 23, 2011 Author Posted August 23, 2011 trying to do a conersion dropped new engine in and trying to wire it up but running into some problems that can not figure out at all Quote
ryan lang Posted August 23, 2011 Posted August 23, 2011 i think he's doing the FTE conversion micky Quote
micky boy Posted August 23, 2011 Posted August 23, 2011 Orr right so you must be useing an auto engine loom? so yeah as ryan has said you can use the tb off an auto glanza/GT Quote
