I've had this problem since I've owned the car. It's nothing major but it is annoying!
It's almost like a slight misfire, when I'm going slow in 2nd if I back off the throttle it holds back and then stutters.
Sometimes I get it holding back slightly when I accelerate but it usually clears pretty fast.
I've got new:
Spark plugs
HT Leads
King Lead
Distributor cap and arm
Map sensor
Has anybody else had this problem or got any ideas? Would be much appreciated :)
Cheers
Luke
Had the problem mate but mine was the king lead unfortunatly Soz man its annoying when shit like this happens
idile sensor timeing or needing remap maybe
Forgot to mention I've got a plug and play ECU now to so it's not down to mapping :(
Is setting the idle timing hard to do or require a specific tool?
Not sure if it's this though as sometimes it runs spot on other times it doesn't :D
Brand new distributor as the old one was well worn, it was arcing in there to bridge the gap :)
It's been set up fine though. How would I go about setting up the TPS sensor?
Thanks for all the help guys
Thanks for that Rore, I'll get the timing double checked.
The timing was set up by a mechanic and the problem still existed even with the new one, so I sort of ruled that one out. Worth getting it double check though :)
Quick question though, why would I need the car in diagnostic mode for setting the timing?
I thought you just needed to find top dead centre, then adjust the distributor as necessary?
I did the ignition timing when it wasn't in diagnostic mode and apparently turns off some sensors it ran like shit..
The diagnostic box right near the battery live bridge te1 and e1 I think and set the idle to 800 and 10 degrees btdc and jobs a peach
not to thread hijack but if your gonna change fuel filter i got 1 here u can have cheap ;)
Thanks mate but I get most of my parts trade price :(
Cheers :)
Pretty sure the problem isn't timing or TPS related though :)
seems like it cant be ignition related as you replaced everything.....
i`d check for water down the plug holes
check the earth of the ignitor pack
check the ignition timing with a light
replace the fuel filter
if it still plays up get the injectors cleaned
edit: what grade plugs are you using?
Putting it into diagnostic mode basically gives the car a referance point. It needs to be set in diagnostics mode for the ignition timing to be right.
Takes a minute to check with the right tools, paper clip and timing light.
