Glanza AuA Posted September 2, 2011 Posted September 2, 2011 hi guys i just installed an oil pressure guage on my vthe lowest read my does on hot idle is 30psi and on a high rev 90 psijust wanted to know if these readings are ok or should i change my oil pump or any other concerns!!thx a lot guys will appreciate all the help and info Quote
stavros Posted September 4, 2011 Posted September 4, 2011 Them pressures are fine mate. Personally I prefer my gauges in bar, usually hot idles around 2bar and cold idle/on boost around 6bar. Quote
Amjad Posted September 4, 2011 Posted September 4, 2011 Mine idle's at around 1.2bar when warm and can reach 4bar under load (CT9) Quote
Blitz Posted September 4, 2011 Posted September 4, 2011 Them pressures are fine mate. Personally I prefer my gauges in bar, usually hot idles around 2bar and cold idle/on boost around 6bar.mines similar hot 2 bar cold 4-5bar Quote
Jamie1st Posted September 4, 2011 Posted September 4, 2011 When mines hot, mines about 2.8bar on tickover. Under load, goes up to about 5.5-6bar Quote
