Asad Posted September 12, 2011 Share Posted September 12, 2011 Just ordered mine so might aswell throw all the part numbers in hereWishboneFront wishbone bush (cylinder one with a metal sleeve) 31mm : SPF1905K EP91 only Front wishbone bush (cylinder one with a metal sleeve) 34mm ; SPF1888K EP82 only These bushes are if you DO NOT have a whiteline antilift kit, when fitting these you have to retain the metal tube on the wishbone SPF1906K if you have the long bracket (pic 3+4 in this tutorial http://www.toyotagtturbo.com/forums/showwi...+Anti+Lift+Kit)SPF2635K if you have the normal bracket U shaped one I am unsure why there are two separate bushes made by super pro yet whiteline only make one kit for the starlet, its best to get the full whiteline kit imo as it offers the ability to change caster...a must mod for the starlet but if your budger is tight you can opt for just the bushes Antiroll barThe front standard anti-rollbar is 20mm in diameter : SPF1487/20 (the 20 denotes the diameter these are avaliable from 16-27mm good for people with the TRD antiroll bars)There are two different droplinks for the starlet, one with a ball joint and the other is a straight link....as far as i know the ball joint one is for the EP82 and the straight one is for the EP91. Its easy enough to check on your car, just turn the wheel and have a deek.EP91/Straight linkoption 1) replace the droplink with a new set of standard replacementsoption 2) buy a set of standard replacements and buy these bushes SPF0903K, to replace the standard rubber onesWith all three options there will be a difference as the old bushes are far past there best on our cars, the only difference between option 2 and 3 is how cheap you can source the standard replacement droplinks ont forget to factor in postage costs tooEDIT: i have just read the whiteline droplinks dont fit standard antiroll bars....EP82/Ball joint link option 1) replace the droplink with a new set of standard replacementsoption 2) buy a set of standard replacements and buy these bushes SPF0903-4K, to replace the standard rubber onesWhiteline dont offer a droplink with a ball joint so your only option if you want to go poly is option 2Where to buy??You now have the part numbers so where ever you can get them cheapest really....heres a few to start FensportLarkspeedcamskillmodworldI put my order thru via modworld as i found it was the cheapest, they do not charge for postage if the order is above £10 which makes a nice saving of about £5 from fensport etc i will update my post on how they are to buy from When fitting these bushes make sure you use plenty of the provided white grease, take your time as the captive bolts can come away and cause problemsAs always comments and criticisms welcome Quote Link to post Share on other sites
Asad Posted September 16, 2011 Author Share Posted September 16, 2011 Quick update, i ordered from modworld on the 12th and got the items today....was abit worried as there website looks abit dodgy what with no pictures etc so i phoned up and all was well http://www.modworld.co.uk/just put the part no`s in Quote Link to post Share on other sites
Amjad Posted September 17, 2011 Share Posted September 17, 2011 Nice write up Quote Link to post Share on other sites
Asad Posted September 17, 2011 Author Share Posted September 17, 2011 could a mod merge amjads poly bush thread together with this, taking out the irrelevant stuff? Quote Link to post Share on other sites
