Glanza Mac Posted September 15, 2011 Posted September 15, 2011 parked my glazna on my drive and it was all fine and dandy about half hour later i went to reverse from my drive, put the clutch down and a horrible squeeling/scraping sounds appeared so i came of the clutch pedal and the noise went away :Sput the car in reverse pretty quickly and reversed and drove up my street, the car moves fine but it only makes that noise when the clutch is being pressed down.anyone know what this could be?ive heard its a release bearing thats failed and also the flywheel/crank bearing that has failed? Quote
james@cjperformance Posted September 15, 2011 Posted September 15, 2011 Sound like the release bearing to me. bang a new clutch in while your at it save you pullong the box off again Quote
Glanza Mac Posted September 15, 2011 Author Posted September 15, 2011 how positive do you think its that because i will go buy one asap ? Quote
james@cjperformance Posted September 16, 2011 Posted September 16, 2011 Sit in thd car with it on idle and in neutral. is the noise present? If yes push the clutch pedal down. does the noise go away of yes the im 99% sure its the release bearing Quote
Stui White Posted September 16, 2011 Posted September 16, 2011 I had the same noise in my first ever car (106) and i drove that for 5/6 months fine.Obviously get a new clutch kit with all new bearings and fit it to get rid of the noise. Quote
RobSR Posted September 18, 2011 Posted September 18, 2011 what clutch is it?Can be relaese bearing like mentioned..but you get the same symptoms when it pops springs out to.. Quote
GT Phayer Posted September 18, 2011 Posted September 18, 2011 If its a screeching i recon the release bearing its scraping through the fingers on the pressure plate, have had that before Quote
Glanza Mac Posted September 18, 2011 Author Posted September 18, 2011 padle clutch, yeahh its going in either tomorrow or tuesday so ill let you know how it goes Quote
