my glanza has all of a sudden developed a kind of buzzing noise once I start the car up? It seems like its coming from behind the clocks but im not 100% sure? Has anybody come across this problem in their car?
Any help will be massively appreciated! :)
Just when uv started it? Sounds like the abs unit, nothing to worry about
Yeah just once the cars started? When I indicate the buzzing goes with the ticking of the indication if you know what I mean? Are you on about the abs unit in the engine?
So the buzzing is constant? The abs unit makes a buzzing noise for a few seconds as u turn the key.
your problem must lie elsewhere. Could u explain it inro anymore detail or will it pick the noise up in a video?
Yeah the noise is constant! Il try and get a video of the noise and post it up!
The video didn't really pick up the noise as its quite high pitched? I seem to have narrowed it down to my gauges so I will have a play with them tomorrow and see what I come up with?
Thanks anyway
