BoGlE Posted October 9, 2011 Posted October 9, 2011 Is the return pipe on the sump the same size/diameter as the return pipe coming off the td04 turbo?Thanks Quote
Idrees Posted October 9, 2011 Posted October 9, 2011 Yes, should be 19mm inner diameter on both ends iirc. Quote
BoGlE Posted October 9, 2011 Author Posted October 9, 2011 Yes, should be 19mm inner diameter on both ends iirc.Ok cheers mate Quote
lukEp Posted October 10, 2011 Posted October 10, 2011 This will prob do the job but not sure how long it will last http://www.ebay.co.uk/itm/300575221829?ru=...1#ht_1652wt_938 Quote
